It is currently Sun Jul 27, 2025 11:11 am
PostPosted: Mon Jun 09, 2008 10:07 pm
What is the recommended top thickness for a Martin 00 (lower bout = 14.5") size guitar using spruce for the top?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Tue Jun 10, 2008 8:44 am
I would second Todd's suggestion.
IMHO .105" would be a strict minimum with traditional bracing. Depending how aggressive you are with finish sanding, the top could end up too thin.
I like to use tops that are a tad floppier across the grain for smaller guitars. My range for 0 or 00 size guitars is between .110" and .115" so far. Like Todd I tend to do a bit of perimeter sanding (on both lower bouts and a less in front of the bridge) and see how the top responds, although I like to leave the top area right above the end block full thickness.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Tue Jun 10, 2008 10:15 am
Todd and Laurent, thanks. Just wondered if smaller bodied guitars can go with thinner tops. :D
Rich Smith
Issaquah, WA
